Import Outlook address book” in Avira Internet Security 2012
I keep clicking “Import Outlook address book” in Avira Internet Security 2012 but I always fail.
Another way to do it is to import Windows Mail but that’s also unavailable.
My MacBook Pro is relatively new. It runs with Windows 7 Pro 64-bit. It is equipped with a Boot Camp partition. I also added Office Professional Plus 2010 and recently did a remote full system repair using Microsoft Tech Support.
As you can see, I try my best to keep it safe and clean. That’s why I’m not expecting this error.
If anybody knows the answer, please tell me.
Thanks!
Error loading outlook Address Book.
OK
Best Answer by carpenter harrer
Answered By 0 points N/A #152305
Hi Bray,
It is exactly not any problem. It is a very familiar issue. To get rid of the problem what you will have to do:
Just call the Avira Customer Service and have Premium Products.
If once the premium product in your computer, you should have no problem.
Thanks for asking.
Hathy
Answered By 5 points N/A #152306
Hi Bray,
Your addressbook may be set to a property of read only. You might have to change this property manually. To get the step by step ways in which you shall change this, go to the link below which is from Microsoft as they had earlier solved a similar issue.
https://support.microsoft.com/en-us/help/269777/olexp-error-message-address-book-failed-to-load
For any further assistance on the issue, please notify microsoft or the publisher of your software
