The Importance of Monitoring Hard Drive Activities
Hi to everyone,
What are the advantages of having hard drive monitor? As an IT system administrator in a specific company I have to be aware on the important details in the computer operating system such as updates, hard drive status, reports regarding hard drive and more. And what is the operating system that the hard drive monitor is capable of?
Your suggestion is very much welcome.
Answered By 0 points N/A #184688
Hi Thomas,
On the name itself Hard Drive Monitor it is use in monitoring your hard drive's status. Having Hard Drive Monitor gives you the following advantages:
1. Helps you in monitoring and maintaining your hard drive.
2. Provides you with the detailed report about the status of your hard drive in real time (drive temperature, drive information, spin up time, etc.)
3. Can easily predict hard drive failures and prevent data loss.
Especially that you are an IT system administrator you need to use this to maintain the company's information that are saved in the hard drive and for you to predict before hand any failures that may happened in your computer hard drive. It can be capable in Windows Operating System.
Answered By 5 points N/A #184690
Hello Thomas,
Hard drive monitoring system serves as a diagnostic tool usually used for monitoring all the hard drives in your computer. With the monitoring on, it will give you the detailed report or a status report about the hard disk, errors, disk temperature etc.
The biggest advantage i have found is that it can also be used as future predictor about hard disk failure so you can save your important data on time and make a back up when it happens due to its detailed report.
These kind of software are almost supported by all operating systems. They can be installed on USB or a flash drive. So this feature makes it portable too.
Thanks
