Importance Of Microsoft Windows Installer In Your System
Hello everyone, I have heard the term Microsoft Windows Installer. Why it is significant to keep it and how it can be suitable for my system?
Microsoft Windows Installer is a kind of manual which is provided with Windows. The installer service enables customers to offer better corporate deployment and provides a standard format for component management. The installer also allows the advertisement of applications and features according to the operating system.
Windows Installer enables the efficient installation and configuration of your products and applications running on Windows. The installer provides new abilities to promote types without setting it up, to arrangement products on demand, and to add user customizations.
The Microsoft Windows Installer or simply the Windows Installer is a utility program in the Microsoft Windows operating system that is used for installing applications or software and uses the “.msi” extension name. It is an installation and configuration service provided with the Windows operating system. It provides a way to install application on a computer that complies or follows with the architectural framework of the operating system.
Normally, third-party applications are bundled with the Windows Installer. This allows for correct installation and configuration of the application on a Windows framework. The Windows Installer normally includes an uninstaller, a program used for uninstalling the application. The uninstaller is normally invoked from the Control Panel.
