Important files affected – repare process with maximum file back
There are some important documents in pc has gotten effected and has been detected as threats by my anti-virus. I need to recover them and with maximum file back. I need to know if there is a tool for that which can repair files back to their original form. Kindly someone inform me if there is an application for that.
Herbert Welling
Answered By 0 points N/A #108741
There are different types of antivirus with different version. You did not mention the name of your antivirus and the installation period. However, after installing your antivirus and scanning your files through it you have got affected some of your important documents in PC which has been detected as threats by your antivirus. If it is so, you should contact your antivirus production company and ask them for another version that is compatible with your recent files and filing systems. I think the problem is with the version of your antivirus. If you chose the right version it will be ok.
I hope you understand it.
Thanks
