Frank Trask
10 points
Posted on - 11/25/2012
Where do I find calibri body font for windows 7 for download and how do I reinstall it back into my Windows 7 system after corruption that was caused by an unknown virus through the internet?
cless28
Importing calibri body font for Windows 7 after corruption
Hi Frank!
There will be 2 simple ways on how you can install that "Calibri" font or any other font that you wish to install in future needs. But first you have to download that font style. You can go to this site and check those fonts https://www.1001freefonts.com/ and download those for the Windows platform. After downloading you can do either one of these:
1) One by One Installation
 – After downloading the fonts from the web which are commonly in .rar file, extract it somewhere and then double click the font file one by one and it will automatically be installed.
2) Mass Installation
 – After extracting all the font file, you can copy them all and paste it C:WindowsFonts folder, and they will be installed (assuming it is the C: drive where you installed your OS, if it is in different drive, just change the drive letter).
Hope this will help!
