Please advice on how can I import selected message from my Gmail and Outlook to Thunderbird?
I have around 800 to 1,000 e-mails in my inbox, and I only need to import messages from selected senders.
Is there a quick way to do it?
As I do not have much time to manually select each received messages.
Hope you guys here can help me.
Thank you.
Importing messages from Gmail and Outlook to Thunderbird
Yes, you can do it easily in Thunderbird.
You can import your all mails from your Thunderbird.
Here following the method for fix your problem:
At first you should go on %AppData% and then Thunderbird for find the data in that place, now open Profiles on Windows
Let you open your profile there and then try to find the Local Folders, You will get a file with .msf format.
You will copy that files from there and then paste it in your Outlook Thunderbird area for get this mail.
You may do same process for other mail providers too.
Thanks
