Improved Audacity Portable 2.0 rev.2
The latest audio related Audacity Portable 2.0 rev.2 software works fine. Is there any way of working with saved files that has been recorded by vlc?
Yes, it is very useful since it is in a portable version. You can copy it in any kind of containers like USB flash drive, portable hard drive, iPod, or even in a CD where you actually burn the files on to the disc.
You can use it on any computer that is available and will never leave any of your valuable information behind. It will automatically remove all temporary files that it uses after you use the application.
Audacity Portable 2.0 Rev 2 supports Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows 8. You can use any editions and Service Packs on this program.
This version was last updated on May 10, 2012, just a month ago. To download this version, Audacity Portable 2.0 Rev 2, you may visit Audacity Portable.
