Improving the Performance of my IE
I really need the help of some experts here.
Ive been using Internet Explorer as my web browser for quite some time already.
The problem is, the speed performance of my IE is becoming slower than before.
Is there some way I could improve its performance?
Best Answer by Wright Branda
Answered By 15 points N/A #100989
There are a couple of steps you can try to make your IE performance better.
You need to make sure that your internet explorer is up-to-date. You can also reset your IE settings.
For easy reset you can get the "Reset IE tool" from Microsoft.com.
Follow this link to get there.
Try to disable some add-ons on you browser that you usually don't use. Try making more changes under your browser's settings (e.g. turning off RSS Feeds, disabling clear type, etc).
You can also close some applications that you are not using since it eats up memory off your computer which makes everything run a bit slower.
Lesser applications or programs running the faster your computer performance works.
Answered By 0 points N/A #195431
Hello my dear,
First, remember this, whenever you open any webpage on Internet Explorer, it saves the data into its cache memory, and builds cookies and other scripts in its cache memory. When cache memory reaches its limit, then performance and speed become slower. In your case, it seems that you have not cleared your cache memory and cookies, so this problem is occurring. Clear all of your offline data, cache memory and saved passwords, and delete all of your cookies. Then, you will see that performance and speed have increased.
Answered By 590495 points N/A #329545
If you love using Windows Internet Explorer and you are starting to have problems with the browser, try updating if you haven’t done it yet. Update your version from the following:
Check the system requirements first before downloading and make sure your computer meets those requirements. Installing the latest Service Pack also updates Windows Internet Explorer. If you have Windows XP, you need to update to Service Pack 3. Download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP.
If you encountered an error when updating to Service Pack 3, try updating to Service Pack 2. Download Windows XP Service Pack 2 if you don’t have it yet. You can update to Service Pack 3 once Service Pack 2 is installed. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista.
For Windows 7, download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7. For Windows 8, update to Windows 8.1 from the Microsoft Store.
