In My System, Acpitabl Dat Problem Is Occurring On My System
ACPI stands for the Advanced Configuration and Power Interface that is an open standard and defines a platform for hardware discovery, configuration, power management, and monitoring. The possible cause of the acpitabl dat problem is the CMOS Battery is Dying and Raid Problem. The resolution to fix the issue are as follows:
Solution 1:
Visit CMOS setup and scroll to Power Management setup, then hit Enter. Look at it and hit Esc to exit, then press Y to save.
Solution 2:
Clear the RAID Problem
Step 1: Turn off the server and unplug the hard disk in your RAID.
Step 2: Boot the server and the status of the RAID will change to degraded.
Step 3: A new login screen will appear on the screen, then login into the server and perform a necessary backup.
Step 4: Plug the hard disk in and rebuild the RAID array with its software.
