In The Online Activation Of KMS, It Gives 0xc004f074 Error
Explain about the 0xc004f074 error? what is the cause of the error code and explain the methods to overcome this error message?
When the user tries to upgrade to the new Windows then error 0xc004f074 displays. Windows is unable to reach the company’s activation service. 0xc004f074 error code indicates that KMS (Key Management Service) cannot be contracted during the activation procedure. The methods to fix the 0xc004f074 error code are as follows:
Change the Key using the activation wizard.
Step 1: Hold Windows Key+ R and type ‘slui 4’ then press Enter.
Step 2: Now, hold Windows Key+ S to open settings.
Step 3: Select Update & security and click on Activation.
Step 4: The user will receive an option Activate by phone.
Step 5: Start the Product Activation Wizard.
Step 6: Open charms menu and select Settings.
Step 7: Go to Change PC Settings and click on Activate Windows.
Restart the system and perform your task.
