In The Online Searching Of Updates, It Gives 800f080d Error
Explain about the 800f080d error? What is the cause of the error code, and explain the methods to overcome this error message?
Windows update error code 800f080d occurs when the system files become corrupted due to the hard disk problem or after a virus attack. This error occurs when the user tries to search for the new Windows update. The description of the error code ‘Windows could not search for new updates Error(s) found: Code 800f080d.’
The method to fix the error code is as follows:
Method 1:
Scan the computer for viruses.
Method 2:
Run the Windows SFC scan.
Open the command prompt and type sfc /scannow. Then press Enter.
Method 3:
Run the Windows troubleshooter.
