I am curious is there a shortcut to lock the computer and also a friend of mine was facing a problem with a folder virus. It automatically produces a shortcut folder. Is there any shortcut folder virus remover antivirus software to solve this problem?
In This We Determine The Shortcut To Lock The Computer And Is There Any Shortcut Folder Virus Remover Software
The shortcut key to lock the computer in windows is the Windows key + L key both pressed together to lock your computer.
According to me, the antivirus software for shortcut folder virus remover is Avast Total Security. You can utilize it to scan your drive infected with this virus and it will automatically delete and remove it from your affected system. I have used it and it works just fine.
