In Windows 7 Add Active Directory Users And Computersmanually.
Asked By 5 points N/A Posted on -
I want to ask in windows 7 add active directory users and computers. I have aWindows7 operating system with 64-bit installation. How can I use active directory users and computers on my computer? Any suggestions would be appreciated.
Answered By 0 points N/A #293146
First and foremost, install the package from the following link
http://www.microsoft.com/en-AU/download/details.aspx?id=7887
You will get the appropriate file for your 64-bit system there.
Install the file you downloaded on your computer. Within few click, it will be installed on your device.  Then, open “Programs and Features” from the control panel. In the left pane of the window, click on “Turn Windows features on or off.” Check the “Active Directory Administrative Centre” checkbox in the window that pops up as shown below.
Click “OK” to apply the changes.
