Inbox2 application error has occured
Friends I am getting this error message when I am performing an action in Inbox. I am not a technical person, not able to understand error. Please explain me the root cause of this error. I need to label the email to make to easy, getting tired to searching an email. Please me to rectify this error. Thanks a lot.
Oops, an error has occured
We are very sorry for this and have sent the details of this error to the Inbox2 master jedi’s to take a look at.
Object reference not set to an instance of an object.
Answered By 590495 points N/A #180755
If you are using Inbox2 0.5.0.1b, make sure you are running Windows 2000, Windows XP, Windows Vista, or Windows 7. It doesn’t support Microsoft Windows 8 and I don’t think if it’ll support Microsoft Windows 8 because this version was written almost three years ago, 2011. It doesn’t support other operating systems only Microsoft Windows.
Try reinstalling the program. Uninstall Inbox2 and then click Start, All Programs, Accessories, System Tools, and select Disk Cleanup. Select drive C and click OK. Check “Temporary files”, and click OK. Wait for it to finish and restart your computer. Install Inbox2 again and see if it works. In case you want to download the installer again or you are using an older version and you want to upgrade, download Inbox2 0.5.0.1b.
