Hi Experts,
I have failed to run Adobe Photoshop CS3 on my machine. It is indicating something regarding processor’s incompatibility. My machine is running with Intel Core 2 Duo E8600 processor. Have you any idea for the incompatibility?
Please guide me to do the needful.
Thanks in advance.
Incompatibility issue with the processor in running Adobe Photoshop CS3
When other applications are running, the Photoshop might be failed to run. I don’t know the exact reason for this issue. But I guess this might be happen for low performance of the system.
Please try to remove other applications which are running background and also you have to disable unnecessary system startup applications.
Click start then type msconfig in the search box and run this application.
Select selective startup in the General tab.
In the Startup tab, Please click Disable All.
In the Service tab, choose hide all Microsoft Services and then click Disable All.
Restart the windows after apply the settings.
If this problem still occurs, update your operating system. This will improve the system performance with applications.
Hope this will solve your problem.
