Incorporation to WordPress Ribbon Menu PHP CSS
Hi. I am currentlydeveloping a website in WordPress. I'm just having a plain menu and I find it boring so I thought of using Ribbon Menu to my WordPress. Below is the code of my Main Menu:
<?php wp_nav_menu( array( 'theme_location' => 'primary' ) ); ?>
I want to incorporate the code of that menu to my current code of my Main menu. Please help in adding the Ribbon Menu PHP CSS code, your help will highly be appreciated. Thanks guys!
Answered By 0 points N/A #148350
Now days everybody want to make nice looking menu bar for your project,then ribbon menu bar definitely helps you to make different types of menu bar. It adds a different look to it . The word press navigation bar should be style within the interface. There are quite a few script's are available on the internet. elements are there for the 3D or animated navigation bar. Now here is the couple link which will be helpful for you
http://www.jacklmoore.com/notes/css3-ribbon-menu/
http://diythemes.com
Thanks
