Increasing resolution of a video
Hi everyone, is there any software which can increase the resolution of a video to make it clearer?
Please suggest one.
Please suggest one.
You can go for Video Enhancer Software.
It preserves the quality of your original clip and increases your video file resolution. It has Virtual Dub filters, and they try to edit your video by adding brightness, color, decreasing noise and hence improving the quality and resolution.It works on all window versions.
Keep in mind the configuration process when using the same.
The cons of Video enhancer is that it stresses your system when trying to process new Video.
But with good configuration process in mind, it can do a real amazing job.
You can download the same using this link:
Please try the following software's in order to enhance the video resolutions.
You can try anyone out of below 02 software's:
1. Video Enhancer 1.9.7
2. FixMyMovie
Both softwares have the quality to enhance video quality, lightning issues and overall resolution problems.
Great! I thought there is no such thing on net.
I was really searching on this since last week.Â
Grateful to be in this site.
Thank you Jane.
