Increase my android volume through android audio booster version 1.2.9 APK
Hello, How can I increase my android volume up to 30%? I viewed on the internet that I can increase my android volume through android audio booster version 1.2.9 APK. Please can you inform me if I do that any problems occur on my phone?
Answered By 0 points N/A #166551
Hello Jasonf,
Technically, if you increase your Android phone volume level (loudspeaker), it could shorten its lifetime.
It is not recommended to listen to audio for prolonged times with boosted audio.
I advise if you plan to use, don't increase boost level past 40%.
Anything past 40% can really damage your loudspeaker if listened for prolonged time, not to mentioned your hearing.
You can download mentioned app here.
I hope this solves your problem.
