Increase The Security By Learning How Do I Lock My ipad
Hi. I am using an iPad and I would like to know the steps which should be followed so as to know how do I lock my iPad. Also, what are the steps to change the password? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #85013
Hi. The steps to change an old password include-
1) Once you reach the enter passcode screen on your iPad by swiping the screen right, enter the passcode
2) Click on the settings icon
3) Click on the passcode option
4) Enter the passcde when asked for
5) Click on change passcode and type the old passcode again when prompted
6) Type the passcode being used by you to unlock the iPad
7) Now, enter the passcode to which you want the previous passcode to be changed
8) Type the passcode again so as to verify it and if the two new passcodes match, you will be directed to the passcode lock screen
9) The iPad can be locked by pressing the lock button
10) Again, type the new passcode to check if it unlocks the iPad or not
The steps to be followed so as to learn how do I lock my iPad are-
1) Go to the settings icon and click on it
2) Click on the passcode option and then select turn passcode on option
3) If touch ID is supported by the device, then it will be called touch ID and passcode
4) Click on turn passcode on and enter the six-digit passcode required
5) Enter the passcode twice so as to confirm it and if they match, you will be directed to the passcode lock screen
6) Then, check if the passcode is working or not by entering it on the starting passcode lock screen
Hope we helped.
