Increase Your IT Knowledge By Learning How To Backup Dell Laptop
Hi. I am a Dell user. How to backup Dell laptop? Also, what makes Dell all the more useful? Please reply ASAP. Thanks in advance.
Hi. To learn how to backup Dell laptop, follow the steps as-
1) Method-1: Use the built-in tool
• You can click on start menu
• Then select safeguard
• Click on the backup and recovery option
• On the left-side, click on the create system image option
• Select the location where the backup is to be placed
• Click on start backup option
2) Method-2:Â AOMEI Backupper
• Download and then install the software
• Click on Backup and then select the system backup option
• Enter the name of the task and then select the destination path. Click on start backup option
• After the progress bar reaches 100%, click on Finish to end the process of backup Dell laptops are useful because-
• They are fast and are simple to operate
• The interface is not very complex and it is easy to use
• The security can be increased by putting up a password to access a particular application
Hope we helped.
