Increase Your Knowledge By Learning How Much Does 1GB Of RAM Cost
Hi. I want to buy 1GB of RAM. So, could you give me information about how much does 1GB of RAM cost? Thanks in advance. Please reply as soon as possible.
Hi. Information about how much does 1GB of RAM cost is as follows-
1) The Kingston 1GB DDR RAM is of Rs. 2000
2) The Transcend 1GB DDR RAM is of Rs. 1950
3) The Transcend 1GB DDR2 RAM is of Rs. 650
4) The Transcend 1GB 800 MHz DDR2 RAM is of Rs. 750
5) The Kingston 1GB DDR2 RAM is of Rs. 700
6) The Kingston 1GB 800 MHz DDR2 RAM is of Rs. 850
7) The Corsair 1GB DDR2 RAM is of Rs. 950
8) The OCZ 1GB DDR2 RAM is of Rs. 750
1GB memory is sufficient for performing tasks such as browsing the web, image editing, and e-mail. However, 1GB RAM is not sufficient for gamers. For a perfect gaming experience, you can increase the RAM to up to 8GB.
Hope we helped.
Buying 1 GB of RAM would depend on the brand and how many modules. Most of the online stores sold it by package like when they sell 2 GB RAM they would mean 2 pieces 1 GB memory modules or sometimes one piece 2 GB memory module depending on the type like if it is DDR1, DDR2, or DDR3.
Before buying, you must always check the item’s specifications as well as if it is ECC or non-ECC type to make sure it is compatible with your motherboard. Since you are looking for 1 GB RAM, check this posting on eBay: 1GB PC3200 DDR400 400MHz Desktop PC. It costs around $3.15 excluding the postage. This item is located in Hong Kong.
When buying computer parts online, I always look for postings with free shipping. Another one you may want to check is VINTAGE CORSAIR 1GB DDR 400MHZ RAM. It costs around $9.95 also excluding the postage. Postage, by the way, depends on your location or where the item will be shipped to. This item is located in the United States.
