Increase Your Security: Learn How To Block A Website On Firefox
Hi. I use the browser Mozilla Firefox. I want to know how to block a website on Firefox, view the list of the blocked websites and also block many sites at once? Can all the above be performed on Firefox? Your response is awaited. Thanks in advance.
Answered By 25 points N/A #82548
. Hi. Yes, all three tasks can be performed on Mozilla Firefox.
• To block a website on Firefox for a single site:
1) Start>Mozilla Firefox>Visit the website to be blocked
2) After you right click on the page, a menu will open up from which you need to select View Page Info.
3) After the window opens up, click on permissions.
4) Set Cookies>Unmark the option “use default”
5) The setting needs to be changed to block
6) Close the window of page info.
• To view a list of blocked websites:
1) Select the menu option indicated on the top right corner of the browser
2) Click on Options
3) Click on privacy option
4) Set history Firefox will to: “use custom settings for history”
• To block many sites/all sites:
2) Click on Options
4) The history option of Firefox should be set to “use custom settings for history”
5) Unmark the option “Accept cookies from sites”
6) Close the page and all your changes will be saved automatically
