Increase Your Skil To Install The Hp Psc 2355 Ink Cartridge
Hi. I do not have a very computer-related knowledge. I want to know the steps to install and remove the HP PSC 2355 ink cartridge. Please reply ASAP. Thanks in advance.
Hi. The steps to remove the HP PSC 2355 ink cartridge and installing a new one require you to open the printer first by ensuring that the printer is on and after the cover of the printer is opened, wait until the print cartridge is silent. Next, remove the old cartridges by pressing down the end of each cartridge and then slide it out. Then, use the protector of the cartridge and ensure that the new cartridges are compatible by visiting the HP SureSupply and then select the correct location which appear at the end of the page. Then, the instructions appearing on the screen need to be followed so as to check the compatibility of the cartridge with the printer.
Next, the new cartridges need to be installed by removing the protective tape. Push the cartridge forward so that it fits into place and then close the cover. Hope we helped.
