Nica Ajos
Posted on - 07/22/2016
Often while we are running a program that is using the maximum capacity of our processor or overclocking we come across severe heating issue which is often caused as the cooler fan is provided with a limit at the BIOS. How to maximize cooling efficiency?
ksammrah
Increasing Fan Speed On An Overheating Computer
Generally cooling fans are configured to increase their speed when using applications that maximize processor overhead or other heating tasks like burning or writing big files to disk but often fan speed limits are given on BIOS setup which prevents the fan to reach its maximum speed. This can be solved by the following steps.
a) While booting your pc keep pressing f2 or f4 key to open the bios setup menu
b) Select the rightmost option from the tabs and you would find the option for fan speed at the bottom and set the speed to maximum. That should solve your problem.
