Mike stev
220 points
Posted on - 04/25/2011
I have many software that are not registered but I want to use for long time.
But when the trial period is expired, then these software are not working until I reinstall windows.
I want to use them in same windows.
Any one can get me out of this problem.
Mike
How to increase trial period when expired?
Hi mike,
You can use the software that increase the trail period which you want and I have give you like below where you can download this software.
This software not fix the problem because by using this we only change the software that are present on your desktop it not support to auto run software like Internet Download Manager. When you want to download you can't run with RUNASDATE.
Najam
You also fix your problem by registry cleaner software which reset your registry. All the software that are installed create registry file in which all trail information are stored.
Najam
I was encounter this problem when my IDM was expire and I installed again but same registered problem was still. First Uninstall the desire software and then type REGEDIT in your run command. Then HKey Local Machine-> software, Hkey Local User-> software, from both delete the whole folder which software you want to delete. Re install software I hope you will fix your problem.
