Indent data within a cell
Hi dear,
I have these problems.
Please provide me guidance.
Indenting data within a cell and rotating text to any angle.
Thanks
Hi dear,
Thanks
To indent data within a cell
Before Rotation
And then use the spinner controls to add the required indent.
Select OK
To rotate text to any angle
After Rotation
In Microsoft excel you are able to indent and rotate text within a cell easily.
I will show you by using an example.
We will just think that you may have typed the following headings in an excel sheet.
Those heading are in the right side bottom in each cell.
However,you can change the indent of these headings as follows.
First select all the headings and right click. Then click format cell.
Now click on the alignment Tab and select any type from “Horizontal” dropdown list to change the position horizontally. (I selected the “Center”)
Then select any type from “Vertical” dropdown list to change the position vertically. (I selected “Center”)
Now you can see the indent of the headings has been change as followed.
Similarly you can change the orientation of text.
First select the heading and right click, format cell, alignment tab as previous.
Then click on the red box in orientation section and rotate it to any angle as you wish.
Now orientation will have been changed of the text as follows.
