Hello experts,
I want to run InDesign 3, but I was unlucky, I am getting a problem connected with Adobe’s activation code.
According to Laplink I get the following error message.
AMT Subsystem Failure
The licensing subsystem has failed catastrophically. You must reinstall or call
customer supports.
OK
Please give me a solution.
Thanks in advance.
InDesign 3 – AMT Subsystem Failure
Hello Gloria,
The following solution should help you solve that problem:
You will have to make sure that the executable file of the application is found in the folder that it was installed in as follows:
For windows OS: You will check the following directory: C:Program FilesAdobe[application name]
For Mac OS you will check the following directory: Application folder/[application name]
Another way to solve the problem will be restarting the FLEXnet Licensing Service, and the re-enabling it later. Note that this can be done for windows OS only. The following is a process showing how you will do it:
You will need to access the Administrative Tools control panel.
And then double click on Services.
Locate the FLEXnet Licensing Service and then double click on it to open its properties.
Thereafter you will change Startup Type to manual, restart the service and the restart the application.
Carl
