Hi guys,
After a successful installation of Image Quest 10.3, I decided to click on the Indexing Queue link from IQ desktop and an error message below was executed.
What is the meaning of this?
Can anyone help me?
Error:
Unhandled exception has occurred in a component in your application. If you click Continue,the application will ignore this error and attempt to continue. If you click Quit,the application will close immediately.
The specified module could not be found.(Exception from HRESULT:0x8007007E).
Indexing Queue link from IQ desktop error
It could be that there is a missing file.
So to fix your problem, you just have to download the image quest 10.3 hotfix available on informasoftware.com. But since I am here to help, here is the link to download the hotfix
After downloading, before you apply the hotfix you should close all applications related to IQdesktop, ImageQuest server, client, etc.
Once closed, you just have to extract the downloaded hotfix on folders listed below and make sure to overwrite the existing files.
C:Program FilesInforma SoftwareImageQuestClientToolsClient
C:Program FilesInforma SoftwareImageQuestWebIQbin
C:Program FilesInforma SoftwareImageQuestIQfolder
C:Program FilesInforma SoftwareImageQuestIQocr
C:Program FilesInforma SoftwareImageQuestIQocrOcr Process
C:Program FilesInforma SoftwareTeleformConnector
