Infopath cannot submit the form
I have an environmental setup of Windows Vista Enterprise Systems with customized Infopath form.The version of MS Infopath installed in my system is 2007.
 I have been receiving the following error in an attempt to use the form- "Infopath cannot submit the form.The OnSubmitRequest event handler did not work." The issue is not specific to the form as it works on some workstations.Hence I am sure the form is not the culprit here.What else can be possible involved ?
Cheers
