Informatica sequence generator – workflow executed – failed
Can anybody help me how to fix my informatica generator setting? I made some modifications in the setting. Please look at the screenshots below for the details. I received some errors and tested workflow, it failed. I hope to get response from you guys. Thank you!
Severity: ERROR
Node: node01_myETL
Thread: MAPPING
Process ID: 5060
Message Code: TE_7007
Message: Transformation Evaluation Error [<<Expression Error>> [ERROR]: transformation error… nl:ERROR(u:'transformation error')]
Error:
Access denied.You must need to login below or register to access this page.
Answered By 590495 points N/A #154190
If this is the first time you encounter this error, try restarting the computer then try again. If still nothing happened on the next attempt, try uninstalling the program then check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities,
Norton SystemWorks, or PC Tools Performance Toolkit. After that, install the application again. Doing this will fix any corrupted files in the installation and will restore the settings back to default including some missing files. Try opening the program again.
You may also try upgrading the application if you are using an older version.
