Hi. I want to buy Dell 5650 5.1 surround sound speakers. I have no idea about the product, its features, and dimensions, etc. Can you update me with the same and also list down the steps for installing it. It is urgent. Thanks in advance.
Z. Jony
5 points
Information About Dell 5650 5.1 Surround Sound Speakers
Hi. The Dell 5650 5.1 surround sound speakers is a model of Dell which 5+ subwoofer speakers, 100 Watt output of power, wired connection and a speaker frequency response in the range 40-20,000 Hertz. The model number is 5650. It offers excellent sound quality and clear sound. The dimensions of the speaker are such that the width is 2.5 inch, height is 9.5 inch, depth is 2.5 inch, and the dimensions of the subwoofer are such that the width is 5.1 inch, the height is 9.48 inch, and the depth is 7.9 inch.
The steps for installation-
1) First connect the center speaker to the back of the CPU
2) Now, connect the speakers
3) The input should then be connected to the computer
4) Plug the switch into the wall and turn the power switch on
5) Now, the center speaker can be turned on
Hope we helped.
