Information about hp laptop and notebook
Is there anyone knows about HP probook 430?
Can you tell me about it's processor and others?
Hi Mr. Sattar, Thanks for your question.
HP 430 probook is the best version of HP laptop computers.It is built in with 2nd generation Intel core i3 processor in 2.4oGHz.Ram is 2.00GB with 32bit operating system.You can use windows 7 and windows 8 with this. No pen or touch input available for the display. These are the basic information about HP430 probook.
Have a good day.
Hi RÂ Sattar,
There is two HP Probook model available in the market. First is HP ProBook 4430s Notebook PC (ENERGY STAR) (A9D44PA) and Second is HP ProBook 4430s Notebook PC (A9D49PA). These models are available in different-different configurations. You can customize that. The specification is:
1. Operating system
Windows® 7 Professional 32
Windows® 7 Professional 64
Windows® 7 Home Premium 32
Windows® 7 Home Premium 64
Windows® 7 Home Basic 32
Windows® 7 Starter
SUSEÂ Linux Enterprise 11
FreeDOS
2. Processors
Intel® Core™ i7-2630QM (2.00 GHz, 6 MB L3 cache)
Intel® Core™ i7-2620M (2.70 GHz, 4 MB L3 cache)
Intel® Core™ i5-2540M (2.60 GHz, 3 MB L3 cache)
Intel® Core™ i5-2520M (2.50 GHz, 3 MB L3 cache)
Intel® Core™ i5-2450M (2.50 GHz, 3 MB L3 cache)
Intel® Core™ i5-2430M (2.40 GHz, 3 MB L3 cache)
Intel® Core™ i5-2410M (2.30 GHz, 3 MB L3 cache)
Intel® Core™ i3-2370M (2.40 GHz, 3 MB L3 cache)
Intel® Core™ i3-2330M (2.20 GHz, 3 MB L3 cache)
Intel® Core™ i3-2310M (2.10 GHz, 3 MB L3 cache)
Intel® Pentium® B960 (2.20 GHz, 2 MB L3 cache)
Intel® Celeron® B840 (1.90 GHz, 2 MB L3 cache)
Intel® Celeron® B810 (1.60 GHz, 2 MB L3 cache)
3. Memory, maximum
8 GB 1333 MHz DDR3 SDRAM
4. Internal drive
SATAÂ II (7200Â RPM)
Up to: 750 GB
SATAÂ II (5400Â RPM)
Up to: 750 GB
5. Optical drive
Blu-ray R/RE DVD+/-RW SuperMulti DL
DVD-ROM
6. Display
14" diagonal LED-backlit HD anti-glare; 14" diagonal LED-backlit HD BrightView
Graphics
Integrated: Intel® HD Graphics 3000 or Intel® HD Graphics for Celeron
You can also find more information here : http://www8.hp.com/in/en/products/laptops/index.html
Thank You.
Hi R. Sattar,
Here are some specs of the HP Probook 430 that you asked about:
Processor: Intel Core i3/ 210 GHz/ 64-bit / Intel HM65 Chipset
Memory: 2GB DDR 3 RAM expandable to 8GB
Storage: 500GB SATA hard drive
Graphics Processor: Intel HD Graphics 3000
Display: 16:9 ratio 14.1" LED Screen
USB Ports: 3
Camera: 1.3 Mega Pixels
There are many websites on the internet that you can look into if you are looking for information about computers, their specs and prices. Your search only gets narrower if you have a specific brand and model that you would like to look into. Here are some sites that you can visit if you want to look into more of the specs of what you are searching for:
I hope I have answered your question.
Key Specifications of HP Probook 430.
Processor2nd Generation Core i3.
System Memory2 GB DDR3.
Operating System Free DOS.
Screen Size14.0 Inch.
Graphic Processor Intel HD Graphics.
Web Camera0.3 Megapixel.
Weight 2.20 Kg.
Price USD 535.
HP Probook 430 price is USD 535 and this is the updated and revised price of HP Probook 430 in the USA but price fluctuates in the USA regularly although the price of HP Probook 430 is revised everyday.
There are some slight differences between HP ProBook and the normal laptop. HP ProBook computers developed targeting the business class people so that it contains some additional features such as figure print reader for enhanced security, Reduced overheating and even with a faster hard drive. So obviously it’s bit expensive.
If you need these additional features you can buy the ProBook otherwise if you are a normal computer guy or a programmer I think these additional features does not have much necessity. Â
You can see a good comparison between ProBook and a normal laptop in this link.
