Information about a mobile application…
Hello Mr. Amin,
Tweetcaster is an app for micro-blogging site twitter. Though this is an app, but you can use this like any other software. You can use this on computer,tablet and smart phones. It supports android system too. This is very easy to use and responses really fast. Using this app, you can read the tweets on your timeline, see others profile and links. You can do filtering and add photos. This is actually the number one mobile app for twitter. You can download this file from https://play.google.com/store/apps/details?id=com.handmark.tweetcaster. Enjoy tweeting using this wonderful feature.
Thank you for your question.
Hello Ruhul,
Tweet Caster is the most widely used twitter apps available in android phones. Yes! you can download the application through Google Play Store.Â
Make sure that you have very strong access to wifi spots so you can download it easily.
Find Tweet Caster within your Play Store Icon application. Search it and download the great android app for free.
Have fun using the application.
Hope this very easy solution rectifies your query.
