Information about the process ‘img to iso win’ please
hi everybody, please inform about the common errors related to' img to iso win' the sooner the better thank you in advance
There could be lot of error that may be recorded when you try to change from img to iso. When ever you try to change extensions or convert to some other extension of Image files or ISO files. Make sure you have winrar installed and an ISO maker installed in your system.
First you need to extract all the files present in that using winrar. Then you need to use the third party ISO generators to generate an ISO from those files. Is a quite simple process. But we need to make sure that the files are not getting corrupted.
This is the only thing that we need to follow.
