I have a Windows PC, and recently I have come across this error saying that PSHED.dll is missing from my system. Can someone brief me about what this DLL file is, and why is it missing, and if it is important for the system at all times?
Information About PSHED DLL And What Is It Used For?
The PSHED is a DLL file, developed by Microsoft, and it is an essential system file for the Windows OS. It contains a set of driver functions and procedures that may be used by the OS. It is essential because it makes sure that the Windows programs are functioning. So if this file is missing, then it is necessary to get it back.
To solve this, you can use WikiDll Fixer to automatically repair this error. I suggest this one because not only does it download the correct version, but also shows you which path would be perfect for having this file in and also helps in dealing with these errors in the future. But make sure that you install the fixer that is compatible with your system and from an authentic site.
Another way to solve this error is to download the DLL from an authentic website and placing it in the correct folder and registering in your system.
