Information about Remote Desktop Manager Auto Fill Feature
I am curious to know about remote desktop manager's auto fill feature.
Can anyone tell me in details about this?
The Auto Fill option helps the user to fill the blank flied of a certain web site.
You have to use the browser extensions for using Auto Fill.
Once you save any data for a specific address you never have to fill it again.
You can gather more knowledge about this in:
Hello Sharipcheney,
Auto fill is a web browser that is available for Internet Explorer version 8.
It supports Chrome, Firefox and IE types of extensions.
Pike Hayt
Hi there,
Auto fill is add-ons which helps you to enter data in software and web.
If of remote desktop manager this feature helps you to enter data in a remote computer through web browser.
This feature supports few browsers which can also help you access accounts and web.
Now you just have to configure the add-ons so that can access the account directly from the add-on.
Once you are done with configuration, you just have to confirm the connection in-between them through remote desktop manager.
Thank you,
Riley weaver.
Notifications
