Information about software for my computer.
1) Solution 1 : A timer to shut down your computer :
Their many software available to shut down your computer quickly at a specific time. Here are some of them listed below :
– Auto Shutdown
– Time Shutdown
2) Solution 2 : (Work Under Vista Operating system)
For this solution, You have to use Task Scheduler by following these instructions :
1) Open Task Scheduler which can be found on system tools menu
2) Create a basic task (can be found on right on the menu of task scheduler)
3) Name it (for example : Shutdown task) and then click on next
4) Choose the shutting down time and then click next.Â
5) Fill other details and click on next
6) Choose now start the program and click next
7) Write shut down under Program/script and type this code –s –f –t 0 in the Add arguments box. Once done, click on Next.
8) Finally click on finish and save the task
Hello Subroto.
Yes, there are some software for this operation. I would suggest you to use Qsd software. You can download this software directly. The file size is 508 kb. Install it on your computer and then extract it. After installation, you will find an icon that shows 'quick shut down'.
Click on it and your computer will shut down very quickly.
Thank you for your question.
