Information about water cooling tech
How much cooling can be achieved using a water cooler? And how costly they are? What are the things I need to be aware before buying one?
Hello Gabriel welcome to techyv.com water cooler is use also to avoid dust, every month maintenance and overheating your computer processor if you do over Clocking you’re system unit. Mainly Branded Water coolers will cost around $289.00 to $349.00 this will all covered the tree hot spot chip in your system unit the processor, board chip and the video card chip.
And also you need to be aware of the socket of your board there are two different socket you need to check before you buy one whether your board is socket LGA 775 or Socket A also known as a Socket 462 commonly use by the AMD today. But I think Almost all water cooler systems today can support both of that socket 775 and 462 it is re adjustable in most all type of socket just try checking it out before buying one.
 Socket LGA 775
Socket A or Socket 462
If you are planning to buy my advice brand is Master cooler and Swifttech
I hope I did help you my friend thanks visiting this site come again for IT help.
Thank you.
