Information about the worm-like Meshworm Robot and its Features
Recently researchers have created a robot called Meshworm robot. What is it?
For what purpose will it be used?
Please tell me in details.
Hallo Charls,
You may have come across several options when it comes to control of real worms, but you might have never come across a worm robot till then. The Meshworm is the latest invention by the researchers at the MIT, Seoul as well Harvard Universities. It is a bot that has been made from artificial muscle that has got flexible mesh tube which has been segmented by loops of nickel or titanium wire.
What the wire does is contracting we as well as squeezing the tube in the event that is heated by current, but it should cut the power and gain its original shape. That will enable creation of a propulsion in a manner that is similar to that of the living kin. Traditional parts can be taken out in order to make it hardy.
Carl
Dear,
The researchers at MIT, Harvard University and Seoul National University has developed a robot called Meshworm. It is a creepy-crawly robot. Meshworm has been made both artificial muscles and a flexible mesh tube. There are a small battery and a circuit running inside the Meshworm body.
Thank you.
