Information about zoom codec h1 please?
There are some possibility that can cause such issue:-
1. The version of windows and windows media player you are using.
2. It has always some problem with 16-bit and 24-bit format .
3. If you have not done system restore.
4. There can also be some incompatible issue on the windows and mac OS.
You can also use the FTP here as an attachment or a free file share like filedropper.com
You might want to go online and download latest version of the H1 driver if you have trouble while you use the code. If you want to download the Codec, you can go to the Zoom® Sound Laboratory | H1. This version has new features and it fixes bug that comes with an older version, the features are (Copied from zoom site):
After download, if you want to upgrade to your firmware in device, first extract file that is downloaded and follow all of the instruction given at page 11 of the “H1 Quick Start Guide”. The newest version of driver can work well with the operating system Windows XP service pack 2 and later, windows Vista service pack 2+, and finally windows 7.
