Information and Difference Between Windows 7 x64 and x86 Versions
What is Windows 7 X64 version and windows X86 versions?
Best Answer by Fraserr thor
Answered By 0 points N/A #162523
X64 and X86 are the two type of processor architecture and X86 stand for 32 bit windows and X64 stand for 64bit of windows.
Every edition of windows 7 comes with these two types
X86 windows 7 edition should install on computers with older processors such as Pentium 4.
X86 Windows 7 Editions does not support more than 4GB RAM.
In addition you can install windows 7 X 86 editions on computers running with x64 processors.
But you can’t install X64 editions of windows on computers running with X86 processor architecture.
Thank You
John Major.
Answered By 0 points N/A #162524
These are two kinds of processor type. There are two kinds of processors: 32-bit (x86) and 64-bit (x64). For this, two kinds of windows are available. If you have 32-bit processor, you have to use Windows 7 32-bit version and if you have 64-bit processor, you have to use Windows 7 64-bit version.
There are huge differences between these two versions.
32-bit (x86)
This is the most common version. It is easy to use. Most of the software we use are generally made for 32-bit version. Almost every software runs in 32-bit version
64-bit (x64)
This is a rare version. Very few people use 64-bit processor and 64-bit windows version. Just only a few software can be run in this version. Though it is speedy than 32-bit, but it is not popular.
Answered By 0 points N/A #162525
Hi Jack Hope,
X86 is a 32-bit platform, and x64 is a 64-bit platform.
32-bit and 64-bit have a connection with the way CPU handles data. The 32-bit system handles large amount of RAM less effective than 64-bit system. 32-bit system can support maximum 3.2G RAM while 64-bit system can support maximum 192GB RAM. Therefore, 64-bit system requires your hardware have to be strong enough to install.
In general, requirements for windows 7 are:
Windows 7 32-bit: 1GHz IA-32 processor, 1GB RAM, 16GB HDD (free space), DirectX 9 graphic processor, DVD-ROM drive (optional)
Windows 7 64-bit: 1GHz x86 or x64 processor, 2GB RAM, 20GB HDD (free space), DirectX 9 graphic processor, DVD-ROM drive (optional)
Hope this help
