Information most popular mobile sites
Hi Experts,
I buy a new Nokia window mobile and looking for the software's for my Nokia mobile, Please suggest me some new most popular mobile sites by which I can download all types of software's. Thanks.
Neil Guyson
Best Answer by Goram Ian
Answered By 60 points N/A #182978
Hi Neil Guyson,
As you know, from Google you can find a lot of forums but the chances of getting the right solution depends on where you post your problems. We have so many different forums to get information about most popular mobile sites.
So classifying and posting them on relevant forums is the best way to get download all applications. I can suggest you some good forums, which are listed below:
  1. http://ovi.sigma.apps.bemobi.com/en_us/?utm_source=store.ovi.com (for Nokia mobile phones)
  2. http://www.mobile9.com/
Answered By 0 points N/A #182979
Hi Neil,
There are many sites that are giving people the opportunity to download all the software without cost. But, all of them are real. I also use a Nokia N78 mobile and downloaded many software for this. I have a good list of sites. Please check them for your software.
  1. http://www.softpedia.com › Windows › Mobile Phone Tools › Nokia
  2. www.phoload.com/phones/48-nokia
  3. www.crazy4mobilez.com/
  4. https://www.download.hr/
That's all. Thanks.
Answered By 15 points N/A #182980
 Hi Neli,
I can show you the most famous and best sites,which has good qualities about their business. The goods, they are given  is too pretty better than others.I have given below the world famous sites for you. Use them and solve your question well.
Answered By 5 points N/A #182981
Hello Neil,
As per my opinion the best website for mobile content download is https://www.getjar.com/. This seems to be the oldest player of the market where you can find all kinds of software you want.
If you are using an android or a windows phone, the best option where you can get software is from the marketplace application installed on your phone.
