Samsung Epic Touch 4G runs on Android OS, v2.3 (Gingerbread) with CPU of Dual-core 1.2GHz ARM Cortex-A9 processor, Mali-400MP GPU, Orion chipset. Samsung Epic Touch 4G features TV-out (via MHL A/V link), Active noise cancelation with dedicated mic, TouchWiz UI v4.0. Samsung Epic Touch 4G has 8 MP Camera with autofocus and LED flash.
It is available in Black Color
Price in India: RS 28000
Features and Highlights:-
A-GPS support
Active noise cancelation with dedicated MIC
NFC support (optional)
Digital compass
MP4/DivX/XviD/WMV/H.264/H.263 player
MP3/WAV/eAAC+/AC3/FLAC player
Document editor (Word, Excel, PowerPoint, PDF)
Google Search, Maps, Gmail,
YouTube, Calendar, Google Talk, Picasa integration
Adobe Flash 10.1 support
Specification:-
NETWORK:
2G Network of CDMA 800 / 1900
3G Network of CDMA2000 1xEV-DO
DISPLAY:
Super AMOLED Plus capacitive touchscreen with 16M colors
4.3 inches screen of 480 x 800 pixels
Gorilla Glass display
TouchWiz UI v4.0
Multi-touch input method
Accelerometer sensor for UI auto-rotate
Touch-sensitive controls
Proximity sensor for auto turn-off
Gyroscope sensor
SOUND:
Ring Tone – Vibration, MP3, Polyphonic, WAV
FM – Yes, Stereo FM Radio with RDS
Music – Yes, Music Formats : MP3, WAV, eAAC+, AC3, FLAC with Loud Speaker and 3.5mm Audio Jack
Hi, the newest Samsung smart phone product is “Samsung Galaxy SIII”. It is designed for humans, Samsung GALAXY S III just gets us. It can see even the “Little things”, like staying awake when you look at it and it keeping track your of loved ones, and it goes beyond smart and fulfills your needs by thinking as you think, just like acting as you act. See its specification below:
The Galaxy Epic Touch 4G, is basically just Samsung Galaxy S2 but with some minor changes from Sprint. With that being said you would be able to get the Samsung Epic Touch 4G from Sprint for $200, with a 2 year contract in the US. This means that it may not get this specific model in the India market easily, but I am pretty sure that the Samsung Galaxy S2 is already available in India.
Here are the specification of the Samsung Epic Touch 4G from Sprint. Display is 4.52 inches with a resolution of 408×800 with a pixel density of 206 pixels per inch. It has additional protection of the Corning Gorilla Glass for its display.
It is run by a dual-core 1.2 GHz Exynos processor and comes with 1GB of RAM and a 16GB internal storage.
The Samsung Galaxy S2 Epic 4G Touch is a 3G Smartphone operating on 2G and 3G network bands using CDMA and EVDO technologies but it is not a GSM device. It was announced to the public on August 2011 and released on September 2011 measuring 130 x 70 x 10 millimeters and weighing 130 grams.
It uses mini-SIM card and has Super AMOLED Plus capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring TouchWiz UI 4.0. It runs on Android 2.3.4 Gingerbread powered by Exynos 4210 Dual chipset, 1.2 GHz Dual-Core Cortex-A9 processor, and Mali-400MP4 GPU. It supports microSD expandable up to 32 GB.
It runs on 1 GB RAM with 16 GB internal storage. The primary camera supports 8 megapixels with f/2.6, LED flash, and autofocus featuring 1/3.2″ sensor size, geo-tagging, touch focus, and face and smile detection. It can record video in 1080p at 30 fps. The secondary camera supports 2 megapixels.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; WiMax; Bluetooth 3.0 with A2DP and aptX support; GPS with A-GPS support; NFC is optional; and microUSB 2.0 with USB Host and MHL TV-out support. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1800 mAh battery with standby time up to 252 hours and talk time up to 8 hours 45 minutes. It is available in black and white colors.
1....
