Information regarding making PDF with editable fields
I am trying to make a PDF with editable fields but do not know how to make it.
Please give me a guideline regarding making PDF with editable fields.
It is not so difficult task. You have to learn it from tutorial websites or YouTube. com.
Install any PDF creating software in your PC. It is easily available and free for download.
Now create the PDF file through it.
Follow the lessons from the above website.
You need to either buy or download trial version of Adobe XL Pro from Adobe's website.
Install, then fill-in the quick sign-up form to use their product. Launch Adobe XL Pro, navigate to Tools in the upper right corner. Click Forms, then Create button.
Upon selecting this, a window will appear asking you to select the source document which is either a scanned doc or a .doc file. To enable readers/users of your pdf to fill your forms and save. Close Form Editing mode. Navigate to Menu, then Save as > Reader Extended Pdf > Enable Extended Features.
A short video tutorial can be found at Adobe's website, follow the link to watch it:
