Ini translator portable error opening the program
I want to use IniTranslator Portable and this error appears every time. Yesterday the program worked just fine and no error appeared until now. Does anyone of you experts can help me fixing this error ? What is causing this one ?
Regards experts !
IniTranslator Portable(PortableApps.com Launcher)
IniTranslator Portable cannot be started. You may wish to re-install to fix this issue. (ERROR: C:Users%USER%DesktopIniTranslator PortableAppAppInfoLauncherINITranslator-P.ini could not be found.
