Initialization failed with error code 80040001
I am receiving an error message frequently with my OS Windows XP Service Pack 3.
Have a look at the error message below. I clicked on Help and try to understand the problem but failed.
Have you any idea for the issue?
Please help me to get a remedy of this issue.
Thanks in advance.
Initialization failed with error code 80040001. For more information click Help, otherwise click OK to reboot.
Best Answer by Ramonag jenniferf
Answered By 0 points N/A #146815
Greetings Mr. Mathias
Error code 80040001 come from a damaged file in your OS ( Operation System). This damaged file can come up from :
  • in-complete installation.
  • un-clean program deletion.
  • Spyware.
  • Virus attack.
  • Incorrect shut down on the computer.
There are 2 solution that you can try :
  1. Restore your PC to a prior date by using System Restore function on your Computer.
  2. Reinstalling your OS again from zero.
Hope this help.
Stonjhon Llison
Answered By 0 points N/A #146816
If you are in a standalone computer, check if there is an assigned ip address on you system through the use of command prompt using the ‘ ipconfig’ command. If there is no assigned ip address in your system, in the command prompt again use the command ‘diskpart’ to check for errors on you system drive.
Note that the ‘diskpart’ command can also format drives, read instructions first before using this command. This is due to corrupted programs in you system and irregular cleaning of that systems programs.
