Inkscape 0.48 installer, I encounter an error
Posted on - 12/15/2012
Good day everyone,
As I run the Inkscape 0.48 installer, I encounter an error which appears in the middle of the process. I think that there is a file that was not installed properly.
Hoping to fix things up, I downloaded LittleCms 2.3 from Sourceforge.
I installed it but the error was not repaired. I have posted the CMS error below. Hopefully someone can give me a solution because I am still new to this and I am having a hard time even in just installing something.
Thank you very much.
"./configure" command:
"checking for LCMS… no
configure: error: –enable-l cms was specified, but appropriate Little Cms development packages could not befound".
