I am normally working on Inkscape 0.46using the Ubuntu Operating System and this version of Inkscape is unable to export all features well to a PDF therefor I thought to use Dev version but I got an error message when I start this version to continue my work. You can see the error message so please guide me to resolve this issue as soon as possible. Thanks in advance.
Inkscape encountered an internal error and will close now.
Hi
Console messages :
1)Open messages then utilities and then console
2) Select 'All messages' from 'LOG DATABASE QUERIES' in the log list on the left.
3) Clear the display ('View -Clear Display' or ⌘K)
Wait for Inkspace crashing after launching it and then copy the messages from the Console window into a new TextEdit document and save it using'plaintext' format)
4)Attach the console log here or pastebin its contents and share the link here
Report
Browse in the finder to 'Home – Library -Logs – DiagnosticReports'
Search the latest crash report from Inskcape
See the crash report or pastebin its contents and share the link here
The report needs to be viewed and then the main error can be fixed. I hope you get it.
