Can anyone tell me Unicode solution because I am receiving problem about Unicode, can any one provide me Unicode Converter?
I am using InPage now, and I want to copy that data and paste it into PowerPoint. Please tell me its solution.
I am trying do it, but I am receiving below error. Error of detail is given below for your understanding. Â Â Â Â Â
Unicode Unicode Solution
Run-time error ‘339’;
Component ‘FM20.DLL’ or one of its dependencies not correctly registered: a file is missing or invalid
                              OK
Haris
Inpage Unicode Unicode Solution Required
Hi there!
As you know InPage is a very efficient tool for typing Urdu and different languages other than English, yet it has its limitations of various types. Sometimes our data typed in InPage should need to be retyped in MS Word or other Office applications for the purpose of editing or better word processing.
For this purpose there have been a large number of software's available which easily convert inpage data to Unicode and we can convert our text to MS applications.
As for your error, it is simply showing that you have not a proper installation of the software I suggest you to re-install it. And further download InPage to Unicode Converter 4.23 for free from this link.
Hope this helps.
Regards.
