Inpage urdu software in Android
I am urdu composer. I want to purchase IBERRY BT07 TABLET PC. Is Inpage will download in Android??? which inpage version will suitable for this???
Well mate, Urdu is an oriental language and there are various software for composing Urdu scripts.
Which scripts will you be using?
The iberry BT07 tablet runs on Android 2.3 Gingerbread. If you want to install and use InPage on this tablet, you need to find a version that runs on Android 2.3 Gingerbread. There are different InPage apps available on Google Play with different Android requirements. You just need to search the one that supports Android Gingerbread. One app you can try is Learn Inpage in Urdu.
It supports Android 2.3.3 Gingerbread and higher. This app is designed to teach InPage Urdu with the use of images and screenshots. Another app that is compatible with the tablet is Urdu Typewriter. It allows you to translate English words to Urdu. It supports Android 2.2 Froyo and higher. You can use it to translate your message in English to Urdu.
Another one you can try is Easy Urdu Keyboard. It allows you to compose a message in Urdu without changing the keyboard language. You can type your message using the English keyboard and it will display the right Urdu words.
